8/[3-4] SOOW Cable Question
Old 10-31-18, 02:29 PM
R
Can someone explain to me what typical application I might need an 8/4 (white,black,red, green) instead of 8/3 (white,black, green) cable?
I inherited a 100' or so of 600v 8/4 soow cable when I bought my house (it was hard wired into an outbuilding panel the previous owner had used to weld a together a dock). I've cut it up and have used it for a couple different applications, including as an extension cord to my welder. I have never needed the red wire, and have always just cut and sealed it on both ends.
Recently, I need a extra twenty feet or so to do a couple of fence repairs and was going to order aonother 50-100' of 600v Soow. I've never ended up needing the red and have no idea if I ever will. Thing is, I'd rather have the extra wire and not need it than need it and not have it.
So, I thought I'd ask...outside of 3-phase, what types of applications might I run across on a ranch (or in a non-commercial equipment wood workshop) might require the 4th red wire?
Old 10-31-18, 03:18 PM
Received 1,321 Votes on 1,221 Posts
With a straight 240v load....... you only need two hots and a ground...... three wire.
With a 120/240v load ..... you need two hots, a neutral and a ground...... four wire.
I use 8/4 for power takeoffs from panels for stage use.
Old 10-31-18, 03:34 PM
R
Thanks...I get the "theory" of its use (240v vs 120/240v), but it is the practical is what I cannot figure out.
So, some real world use like "power takefoffs from panels for stage use" (something I am likely to be doing) that I am after. Personally (just a country guy and by no means an electrician), most of the time I've seen hot/hot/neutral/ground has either been in three phase or in 6 gauge and bigger wire.
Old 10-31-18, 04:43 PM
I have a practical use for it. You don't. So no need to purchase any more 4 wire cable.
I have most of my heavy cabling on CamLoks so I can use it for 120/240 or 240v only depending on how connected. I have a generator in my shed. I keep a 100' 8-4 cable there to connect it to the panel. Saves having to move the generator.
Old 10-31-18, 06:02 PM
R
That was my thinking, but thought it better check first before I found myself in a "if only...". Thanks!
Old 11-01-18, 10:36 AM
I
Received 44 Votes on 42 Posts
Shore power for a large RV would be a possible application. Or hooking up a generator to a transfer panel or temp panel on a construction site.
Old 11-01-18, 10:44 AM
Z
Received 153 Votes on 136 Posts
In residential use, the only thing I can think of requiring that much power at 240/120v is a large portable generator and oven/range (rarely movable). Most other large appliances used in or around a residence are 240v only like a kiln, welder, etc.
There's always Craig's list. You may be able to sell what you have leftover and purchase 8/3 cable, which is really only what you need.
Old 11-01-18, 03:19 PM
T
Received 47 Votes on 46 Posts
L1, L2, N, Gnd is still not 3 phase. That would take a BLK, RED, ORN, and GRN, and maybe WHT for 3 ph 208/120V.
And, yes; there are 5 wire twist lock plugs.
Old 11-02-18, 06:09 AM
Tolyn Ironhand's Avatar
Received 252 Votes on 220 Posts
You can re-identify the white as a hot conductor. So a cable with black, red white and green wires can be used for 3 phase that does not have a neutral requirement.
