Putting Romex in conduit
Old 11-01-18, 09:53 PM
Is electrical cable allowed in conduit inside my house? I brought two new circuits into my house and rather than fish them inside a closet wall to get them to where I want them, I would prefer putting them in conduit. 12/2 wiring with a very short run inside a closet. They will be feeding wall heaters for adjacent rooms. Is Romex allowed in any type of conduit?
Old 11-01-18, 10:22 PM
Received 94 Votes on 83 Posts
You can't run Romex outside, how is the feed entering the house? Sounds like THHN/THWN would be a better choice.
Old 11-01-18, 10:55 PM
UF-B cable outside, I fed it through conduit from where it was buried to where it entered the house.
It was a continuous feed into the house from outside---no splicing where it entered. Is that allowed or is a junction box required where I enter the house? I ran it through floor joists to a closet area under a staircase. There is no sheetrock covering the walls. I figure my option is to run it to the spot I need it and put sheetrock in or run it in some conduit. Although this is UF-B cable I might need to add a junction box and splice some Romex to it. That's why I asked about Romex.
Old 11-01-18, 11:21 PM
Received 1,180 Votes on 1,093 Posts
NM-b (romex) is allowed in conduit...... inside the house. NM-b cannot be used outside.
UF-b is allowed in conduit and is allowed inside and outside so you are ok there.
Old 11-02-18, 10:20 AM
CasualJoe's Avatar
Received 92 Votes on 82 Posts
Where is the service panel located? Is it on the outside wall of the house or on another building?
Old 11-02-18, 10:28 PM
The main panel is on the outside wall of my house. I ran UF-b cable underground to several locations where I entered through side of the house. It would be easier for me to put the cable in conduit inside. I've been looking at conduit fill for PVC and it all seems to apply to conductor size and not the cable so I don't really know what size conduit I should use. From what I could decipher it was 15 conductors of size 12 wire in a 3/4 inch PVC conduit.. But can I put 12/2 cable in 3/4 inch PVC conduit? Maybe I should ask that in a new thread---we'll see.
Old 11-03-18, 06:39 AM
pcboss's Avatar
Received 92 Votes on 79 Posts
Cable.in conduit are.based on the widest dimension.
Old 11-03-18, 06:34 PM
You can't compare loose conductors to cable. You won't find a chart on cable fill because it's usually not done. Sleeving it a short run is popular but trying to pull it thru conduit can be a downright nuisance.
A single 12-2 in 3/4" conduit is fine. Two cables may be tight.
Old 11-03-18, 07:47 PM
It's just one 12/2 cable in the 3/4 inch PVC. Plenty of room and it's a short run in a closet.
Old 11-03-18, 08:27 PM
Sounds like you're all set to wire.
