Need a new circuit in my office.....think i found a solution
Received 0 Votes
I need a new circuit in my office, its overloaded quite a bit, I cant have everything I need on.
I been living in my home for over 3 years and never noticed the plug by our garage is 220v , the plug is kitty corner from my office (where i need the new circuit) on the outside, about 1.5 feet at most. It looks like a big junction box with a 220 plug in it, it has an adapter in it for 110. And all its powering is a light bulb in the shed VIA extension cord. The breaker box has installed a 30 amp breaker and it's labeled "RV" as it must of been there RV plug
I knew the plug was there but thought it was not independent from anything else and just wired with the other garage outlets.
How hard would it be to make the leap from the 220 plug box to my office and wire it for 110? I can keep it 220 if I need to I have a 220 UPS that I can use. As I said it's like 1.5 feet from the box to the outside wall of my office.
Just run outside conduit for 30 amp spec and put in a couple pipes through the office and wire it up inside? I am sure there is more to it than that. Debating on if I can do it myself or hire an electrician as does not look like a lot of work if he/she can use the junction box there if that is what it is.
Received 0 Votes
So i did find out its 120V line. its wired Ground, Neutral, Hot.
Question: if the wire is rated for 30 amp, why can't we use that for an outlet inside? why would we need to drop down to a 20 amp breaker if the wire can handle the amps? BTW I noticed the plug says 20A on it but 30 Amps on the breaker?
We have a friend of a friend handyman coming out sunday to take a look, might be too advanced for me if I have to replace breaker.
Hi, I would remove that outlet, install an appropriate sized weather proof box in its place then run a piece of conduit to the new outlet location, what is on the opposite side of the wall from that 30 Amp outlet?
Geo
Geo
