4-prong plug into 3-prong outlet
This new cooktop (240V, 30A) came with a 4-prong NEMA 14-50 plug; the kitchen outlet is only a 3-prong 10-50.
Was wondering if it is always possible to replace the cord that came with the cooktop by a cord with a 3-prong plug (like many people do for electric dryers) bridging the Grounded Screw and the Neutral Terminal with a jumper? Or is it only possible if the installation manual specifically says so?
Would greatly appreciate any comment and suggestion! Thanks, h.
is the only acceptable way. The connection at the stove will need to be modified according to your stoves manual.
Some of the high tech ranges like induction cookers do not allow rewiring, but every standard range I've seen allows cord replacement and bonding of the neutral and ground inside the range wiring compartment.
Thanks, ibpooks! You are right! I've got it wrong: the cooktop cord has three wires -- red, black, and green and no plug; it should be ready as is for a three-prong outlet. The wall oven, however, has a four-prong plug. I will consult with the manuals tonight to see if any tampering with the factory cord is allowed.
Check the manual and see if it mentions anything about 3 prong or rewiring the cord.
Most ranges and dryers don't come with cord attached because they have no way of knowing which receptacle the customer has.
Most cooktops and wall ovens come with just a whip so the customer can wire in 3 wire or 4 wire depending on what they have.
