Can Romex be run through PVC conduit?
Old 11-13-18, 06:01 PM
Can Romex 14/2 be run through PVC conduit?
I'm wanting to run conduit outside across a doorway with the rest of the Romex running as is through the walls. I should mention that there's blown-in insulation inside the walls. This insulation is basically shredded newspapers that's been treated with fire retardant.
Old 11-13-18, 06:26 PM
Received 18 Votes on 17 Posts
It can run in PVC conduit, however, Romex cannot be run outside regardless of in conduit or not.
You must use THWN or UF-b.
You can install weatherproof junction boxes where the conduit leaves and enters the wall and make splice to NM-b (Romex) or just run UF-b all the way.
