8 gauge wire but low wattage
Old 11-13-18, 09:26 PM
I looking at putting in a wall oven and its electrical rating is 3.9kw at 240v 60hz. The appliance has 8 gauge wire coming out of it and a sticker that says I must use 8ga. Now, I know it’s standard that 8 gauge wire would usually require a 40A breaker but the 3.9kw is screaming a 20A breaker. Am I missing something here? Please help, any insight would be great .
Old 11-13-18, 09:32 PM
Received 370 Votes on 347 Posts
That's unusual. Most appliances just give the operating specs and don't actually list a specific wire size to be used. It is perfectly acceptable to use larger wiring and protect the circuit at a lower amperage based on appliance demand. 3.9kw is only around 16+ amps and could run quite fine on #10 wiring protected at 20A or 30A.
Can you post the model number for that oven ?
Old 11-13-18, 09:41 PM
Sure thing, Model # is WOS51EC0HS00 whirlpool
Old 11-13-18, 10:15 PM
I could find nothing that states that #8 wiring must be used with your oven.
Apparently that whip is used on many different wall oven models which is probably why it's so large.
Old 11-14-18, 04:27 AM
Standby please , when I get home this eve I will check again, I thought it was a sticker on the actual unit itself which quite possibly wouldn’t be on the manuals.
Old 11-14-18, 04:49 PM
It says warning fire hazard, Use eight gauge copper wire
Old 11-14-18, 05:26 PM
I would contact Whirlpool as that is not correct. There is no need to use that sized wire.
Whirlpool customer services/contact-us
