Replacing a light/plug receptable in old 60s mobile home
Received 0 Votes
I think I have a good understanding of wiring until I see this stuff.
So this 60s mobile home has some foreign-to-me wiring at times.
The neutral/white is HOT. The two black wires arent. It seems completely backwards.
After much testing, the "new setup" is the working setup. Light switch works. Outlet works.
1. Why would the neutral be HOT? No black wires are hot.
2. On the new setup, which black wire goes to the light?
Can anyone maybe explain whats going on here?
We don't know what was done in your mobile home but white is not a current carrying conductor.
Based on your picture..... it should not be hot.
Is that what's there...... two black wires and one white wire ?
I've never seen anything other than cable used in a mobile home. A cable would have a white and black wire in it. That would mean two white wires and two black wires. It will be very hard for us to figure out what was done there.
Received 0 Votes
I understand.
On the breaker the wire is black.
i maybe made it more confusing in the diagram. Basically, everything is normal except the white is hot and black is neutral. It's just reversed, so it has to be wired accordingly to work. The original receptacle was wired the same way.
I just can't figure out the scenario for why this is......without tearing down the walls
The breaker controls 3 outlets and all seem to work independently whether this one is wired or not.
It seems like original wiring too. Doesn't look like anyone added this outlet or light. Looks like it came like this with the mobile home.
Received 0 Votes
Ray,
When the wiring is done properly by their wire colors (black to brass, white to silver) only the receptacle works and the switch doesn't. Which I believe is because the "hot" isnt isnt able to transfer power via the cross bar to the switch because it's on the neutral side. Basically reverse polarity
Use a polarized extension cord plugged into a correctly wired receptacle as a reference point. Using a multimeter measure (disconnected) white to the narrow slot of the extension cord. Does it read ~120v?
P.S. Give that non contact tester to your kid to play with.
Received 0 Votes
To be sure I'm understanding. You're saying plug in a polarized cord into a properly wired outlet. Then, touch the troubled outlets' white wire and cross over to the hot of the extension cord?
If you need to buy a multimeter a cheap, $8-$15, one is all you need. Get an analog not digital, Digitals can give strange readings due to induced voltages.
Received 0 Votes
then why is it functioning as a hot?
In the picture, it shows exactly how its set up. Everything works 100% this way. If I flip the white to the silver/neutral screw, and put the black where it normally should go, only the receptacle works, not the switch
