Adding a ground bus bar to main panel
Old 11-24-18, 02:22 PM
I would like to add another bus bar for ground wires. My current one only has 12 holes with ground wires doubled and several tripled in the holes. It would be better for me to put in in another area of the panel because the current one is near the bottom side and have a mess of wiring in front of it. I have a GE panel and there are no holes or nubs that suggest a particular place to add another bus. No holes whatsoever. Is it allowable to drill holes in the panel and put one where I want to?
Old 11-24-18, 03:49 PM
L
Received 105 Votes on 91 Posts
You can drill and tap to install additional bus bars.
You could replace existing bus bar with longer one as well.
Old 11-24-18, 05:07 PM
Tolyn Ironhand's Avatar
Received 352 Votes on 304 Posts
These make it easy to drill and tap holes: https://www.harborfreight.com/sae-dr...set-95528.html
There are also others out there.
