disconnect required for detached garage?
Old 11-28-18, 09:25 AM
C
I just moved to a house with a detached garage 30 ft from the house. The electric to the garage is in the form of a single direct bury circuit from the breaker box in the basement.
In the garage, this circuit goes through a standard SPST household light switch, which turns off all the power in the garage, lights and outlets alike.
Does this kind of "disconnect" meet NEC code requirements, or do I need to have installed a "real" disconnect, and if so, can it be inside the garage or does it have to be mounted outside the garage?
Old 11-28-18, 10:24 AM
A
Received 114 Votes on 105 Posts
If the feed to the garage has an amperage (main house branch circuit breaker) rating small enough (typically 15 amps) for the switch then that switch is good enough.
The switch rating should be stamped on the back of the switch.
Inside near where the feed cable enters is okay.
Old 11-28-18, 08:18 PM
C
Thanks for the quick reply.
The garage is on a 20amp breaker circuit. I assume I can just replace the 15amp switch with a 20amp rated switch and all is good?
Thanks again.
Old 11-28-18, 08:50 PM
L
Received 103 Votes on 90 Posts
You could.
However, as far as I know NEC does not require a disconnect switch for a single circuit.
Don't know if your local jurisdiction requires it.
Old 11-29-18, 08:10 AM
Received 85 Votes on 80 Posts
What's the plans for the garage?
It's always been one of my many pet peeves to see a garage wired like that to "save" money.
It makes it about useless for doing any real work out there because it's so underpowered, trip a breaker and have to stop and walk all the way back to the house to reset it.
