Ground connections not to code - how much to worry?
Received 0 Votes
I spent some time in my panel this weekend installing AFCI breakers (not required but I wanted them for safety...). It seems that my panel doesn’t have enough terminals to properly terminate neutrals 1:1 even if you triple up grounds. It’s an older Westinghouse BR panel circa 1987. (Rated for 30 circuits, only has 31 terminals between the connected neutral and ground buses.)
Because of this a large number of ground wires (~10) are twisted into a massive, tight cable and inserted into a single large terminal. Now I know that’s not to code, but honestly how dangerous could that be at this point? I checked and it (and everything else) is solidly connected to the terminal. The panel has been inspected at least once when I added a circuit and pulled permits. And the home inspector never flagged this.
I added a new ground bus bar while I was at it and moved enough untwisted grounds around so the neutrals are all 1:1 now. I could eventually sort out the twisted ground bundle but I ran out of time to do so this weekend. I’m tempted to leave it until we finish our basement in the spring and let the electrician deal with it then if need be. Particularly as I’m closing in on the rated capacity and may just pay to swap the panel for a new one anyway as part of that. (Or I’d need a subpanel.) Am I wrong that this would be safe for now?
Also, just to triple check...I don’t need a jumper to the new ground bar, correct? No neutrals are landing there. I did have to drill one of my own holes (am using the supplied screws) as the Eaton ground bar holes didn’t line up, but both screws are tight and I read 0 ohms of resisstance from the new bar to the old one.
While it is not to the code, it should work fine as is.
The code doesn't really say how many ground wires you can put under the lug, but it is determined by the manufacturer's spec. Which usually states maximum of 3.
I have seen main panel that did not have neural bonded to the ground, which is not right.
