Heat pump dimming lights
Old 12-20-18, 10:36 AM
Hi I recently installed a heat pump in my grandparents home. When the heat pump blower cuts in, the lights in the house dim for an instant. Any ideas/ solutions?
thanks!
Old 12-20-18, 12:05 PM
Received 261 Votes on 236 Posts
You're going to have to give us a lot more information. Start by describing the power supply setup. How much electrical service is there to the home? How much current does the heat pump consume? Did you install electric emergency heat with the heat pump? If so what size/kw? Did you replace an existing heat pump or is this a new installation?
My first guess is that there is insufficient electrical service. It could also be under sized wiring or poor electrical connections. But we'll know more once you tell us more about what you have.
Old 12-21-18, 05:49 PM
CasualJoe's Avatar
Received 29 Votes on 23 Posts
Sounds pretty normal to me, especially in older subdivisions where three or more houses are served by one transformer.
