60 amp disconnect with 70 amp circuit
Old 12-20-18, 07:03 PM
olydude's Avatar
Howdy,
Have #6 wire run to a detached garage wherein I will be installing an electric on demand hot water heater. The 13kw size calls for a 60 amp circuit and the 16kw size water heater calls for a 70 amp circuit...both using the #6 wire.
I am going to install a non-fused disconnect in front of the water heater, but my question is this: can I use the non-fused 60 amp disconnect if I elect to use the 16kw water heater that requires a 70 amp circuit?
The larger unit draws 66 amps.
Thanks!
Old 12-20-18, 08:06 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If there is already a 120 volt supply to the garage you can't run another power source. Sounds like you need to run a 100 amp subpanel to the garage if your main panel will even support it.
Old 12-20-18, 08:55 PM
Received 374 Votes on 351 Posts
A 16kw heater on #6 wiring is really pushing it.
You can use a disconnect larger than what the circuit is protected at but not smaller.
Old 12-21-18, 05:53 PM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
That would require a 100 amp disconnect.
