Solar powered cooking range
Old 12-21-18, 01:57 PM
N
I need help on makig a solar powered cooker. Eiither directly from 12v 700w solar panels or solar inverters. Also please suggest If any product available in the market for homeuse
Old 12-21-18, 02:10 PM
Received 1,202 Votes on 1,112 Posts
Welcome to the forums.
(You should put non-US in your profile)
I've never seen or heard of a 700w solar panel. It would have to be massive and extremely hard to handle. With high wattage arrays.... cells are put in series to raise the voltage. 12vdc will need to be inverted.
Solar power to resistive heating is not a terribly effective way to cook. You'd need massive battery storage to cook without sunlight or at night.
Most ovens use at least a 2000w element and up to 4500w at 240v.
A typical surface burner is 600-1500w at 240v.
Look into GoSun
