Can you run romex cable across attic trusses?
Old 12-23-18, 10:20 AM
I have a new addition with 2x4 roof trusses and a non occupied attic. Instead of drilling through every wall stud to run my new wiring can I just drill through my wall plates and run my wiring along the top of my ceiling trusses?
Old 12-23-18, 11:21 AM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Yes. Just keep them 6' away from the attic access hole.
Old 12-24-18, 07:39 AM
I'm also looking for a new main breaker panel for this 30x30 in-law addition. The most breakers I would need is 11 or 12, all I find in stores are breaker panels with 20 space or more which makes for a somewhat large for a wall inside the home. I can order a 8 space 16 circuit which would be just the right size, I figured I could put 2 breakers in each space and still have enough room to add a few more breakers if I ever need them. This is the main breaker panel I found and wondering if this one would fulfill my needs. I had to insert a link to the picture because it would not upload..
Homeline 100 Amp 8-Space 16-Circuit Indoor Main Breaker Plug-On Neutral Load Center with Cover
https://www.homedepot.com/p/Square-D...00PC/204836383
Old 12-24-18, 07:47 AM
Geochurchi's Avatar
Received 18 Votes on 18 Posts
Hi, you must have room in your main panel for a breaker to supply this new panel, if so you won’t need a main breaker there, so you could possibly get a panel with more spaces and not need to use twin breakers in the future.
Geo
Old 12-24-18, 08:12 AM
This is a new build 30x30 in-law apartment. I have a main breaker panel in my main home and the power company is going to run new 100 amp service to the apartment in order to keep the main home and apartment service separate. This breaker panel I'm looking at is not a main breaker panel? I can't use it to run new service in the new apartment?
Old 12-24-18, 08:15 AM
Received 12 Votes on 11 Posts
Since this is new construction most places require AFCI for most residential circuits. To do that you need full spaces and twins/tandems don't cut it. You will need the bigger panel.
Old 12-24-18, 08:22 AM
If the apartment is a separate service it will needs it's own metar can and main breaker panel. Don't skimp on the size of the panel. I would use a 20 space 20 circuit 100 amp panel minimum.
Old 12-25-18, 07:31 AM
Ok thanks.. I was just looking for a smaller panel box because it'll be seen from inside the apartment and the 20 space looked to big..
Old 12-25-18, 07:44 AM
Install a nice face frame and cabinet door over panel to help camouflage it. Or you can paint the door the same color as the wall.
