Issue with a switch. Scratching my head
Old 12-23-18, 02:39 PM
I went to replace a switch in my room amd now i cannot get anything to work. Even though using a voltage tester i am getting voltage in the line. It is not a 3 way switch but it is a switch that controls an outlet. I have tried wvery combo and i have power to the red and black. Im very confused
Old 12-23-18, 02:56 PM
Received 33 Votes on 27 Posts
I assume the switch is a single pole. So there was only two wires to disconnect from the old switch and same to hook to new switch. The switch breaks the hot to the outlet and does not matter which wire hooks to what terminal on the switch.
Old 12-23-18, 03:01 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Voltage testers if you mean a non contact tester or not very useful for most testing. Often just confuses the issue using one.
Old 12-23-18, 03:12 PM
Received 8 Votes on 6 Posts
Hi, Two things come to mind. The new switch is no good so check it or a bad connection to the outlet in the first place. If the outlet is the type that has the wires connected in the back I would change it to a side wire connection.
Good Luck Woodbutcher
Old 12-23-18, 04:00 PM
Yes, it was a no contact. With power on it lights up but not off. The swith is not sungle pole. There is a black, red, and grey wire. I have used myltiple new switches thinking the first wa bad. There are a set of whit wires in the box but they are wure nut together. All the plugs are the push in type. With 1 liggt working and the rest not i am assuming sonething isnt connected right. I switch everwire combo i couldm there is power trust me 😬. I felt it. But with every outlet and fixture detecting power i cant figure out wheres the bad.
Old 12-23-18, 05:19 PM
Received 513 Votes on 483 Posts
Black, red and gray ?? Do you have conduit there with single wires ?
Can you post a picture or two of the wiring in the box ?
How-to-insert-pictures
Old 12-23-18, 06:47 PM
I would PJmax but i cant get to the advanced menu
Old 12-23-18, 06:52 PM
ray2047's Avatar
You can not access it from some cell phones but should be abel to from your computer however there seems to be a tech problem right now. PM me and I'll give you my Email so you can send me the pictures to post.
Old 12-23-18, 07:48 PM
Can you post attachments Ray..... I cannot at the current time.
Old 12-23-18, 07:57 PM
ray2047's Avatar
Pete, see reply in lounge. If O/P sends me a couple of pics I plan to remote link.
