20 Neon Chargers
Old 12-30-18, 07:49 AM
20 Neon Chargers
Dear Sirs, is there a danger in being in a room where 20 neon chargers are running at the same time?
They are 12 to 15000 volt 60 mp.
Should special protective clothing be worn?
Old 12-30-18, 08:16 AM
Tolyn Ironhand's Avatar
Received 74 Votes on 66 Posts
As long as you do not touch or mess with the neon when it is on, you are fine to be in the same room. Voltages that high are extremely dangerous and should never be touched. Even standard PPE equipment will not protect you from getting shocked.
I am curious why do you ask?
Old 12-30-18, 08:20 AM
A friend is doing experiments, and while I tried using the laptop computer in the same room, the screen was going crazy.
Old 12-30-18, 09:30 AM
Tell your friend to use extream caution. Voltages that high can kill
There are a lot of magnetic fields going in there, that might be messing with the screens. Normally they do not cause issues with people.
Old 12-31-18, 10:41 AM
Thank you that is what I was looking for.
