can someone check my 3 ph question?
Old 01-02-19, 11:16 AM
Received 10 Votes on 10 Posts
Its a boat/marina question. Sometimes the pedestal is supplied by split 240V/120, but sometimes its 2 legs of 208V. If it is the 208/120V Y arrangement, and I have a 10A load on EACH of the two supplied 120V leg, then what is my neutral current? My vector graph on a napkin shows me 10A/1.7 or about 5.8 Amps.
ie; its not full 3 ph, only 2 legs.
Old 01-02-19, 11:30 AM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
(I didn't do the math) here is the formula to calculate it out: https://www.hunker.com/12470226/how-...utral-currents
Old 01-02-19, 12:00 PM
Received 42 Votes on 40 Posts
You don't do the division by 1.7. When your phase currents are 10A, 10A and 0A, the neutral current will be 10A , assuming resistive or mostly resistive loads. Motors will cause enough shift to have measurably different than 10A.
Old 01-02-19, 12:01 PM
10A it is, per posts 2 and 3; glad I asked!
Old 01-02-19, 12:11 PM
Quite non-intuitive.
If you hold A phase current at 10Amps, C always zero, and vary B phase current, here are some results.
A=B=10; Neut = 10A
A=10, B=0: Neut = 10A
A=10, B-5; Neut = 8.7A
interesting indeed.
