Switched outlet correct?
Old 01-09-19, 10:25 AM
T
Question Switched outlet correct?
Can someone let me know if I have this connected correctly? I've attached pictures of the outlet before I put everything in the box.
I am adding a switched outlet with the power coming from the outlet.
Old 01-09-19, 10:40 AM
Received 1,184 Votes on 1,096 Posts
Welcome to the forums.
Yes.... that is a properly wired switch loop circuit.
The only bad thing is it doesn't bring the neutral to the switch location as required by new code.
Old 01-09-19, 11:04 AM
T
What is the new code now?
Do I just need a 14/3 wire between the switch and outlet? How does that get connected?
Old 01-09-19, 11:14 AM
Black brings power to the switch.
Red is switched back to the receptacle.
White to white for neutral.
