Light power issues
Light power issues
Lights and outlets do not work in hall and main bathroom, have power to switch in and out but lights do not come on. Breaker is good. Was working just fine an then just stopped checked circuit not tripped then used volt meter tested power to switch an all is good. Can u help?
Are you using a no contact tester pen that you just hold close to the wire or are you using a multimeter or other tester that requires you to touch probes to the wires to test for voltage?
checked circuit..... not tripped. Then used volt meter tested power to switch an all is good.
