3 gang box and 4 sets of wires
Old 02-04-19, 11:20 AM
C
I have a 3 gang box which has 4 sets of wires in it. It is planned to have two switches which controls 2 under cabinet lights, and 1 GFCI outlet. The wires are
Set1 (b1, w1, g1)
Set2 (b2, w2, g2)
Set3 (b3, w3, g3)
Set4 (b4, w4, g4)
Currently b1 and b3 are capped together and then two new black wires(b1-new, b3-new) going out of the cap(both HOT)
b2 is by itself with a cap, b4 as well, not hot
All the white are capped together with one new white wire going out of the cap
All the ground are capped together
So guessing by this layout, I think set2 and set4 are for the under cabinet lights, right?
If i am right, what is the correct way to wire all these?
Old 02-04-19, 11:41 AM
Received 1,481 Votes on 1,369 Posts
What do the switches do now ?
Did someone prewire this and you are just now using it ?
set 1 and set 3 are feed in and feed out.
set 2 and set 4 could be for the lights if you have wires hanging out under cabinet not connected.
Old 02-04-19, 12:10 PM
C
They are newly added lights, the contractor had to leave for his heart surgery and there are things left here and there and I am trying to pick up.
Old 02-04-19, 12:17 PM
Ok.... I guess you've found the two cables under the cabinets for the lights....
The B1 and B3 black connection needs three loose black tails. One to each switch and one to the receptacle. The white tail is already there for the receptacle. The two capped wires go one wire to each switch.
Old 02-04-19, 02:31 PM
C
Thanks!
There is no cables under the cabinets, two outlets in the cabinets instead. (the light will be plugged in the outlets)
So do I need to worry about the ground wires at all?
and only one white tail goes to the receptacle, the switches don't need white?
Old 02-04-19, 03:31 PM
The switches don't need neutral but they do need to be grounded as that's a plastic box. You can add tails on to that ground bundle. You could loop from switch to switch with ground and make one connection to the splice.
Old 02-04-19, 03:34 PM
C
I guess the GFCI also needs ground, correct? Thank you Sir for helping out!
Old 02-04-19, 03:46 PM
Yes.... the GFI receptacle is included.
Old 02-04-19, 07:23 PM
pcboss's Avatar
Received 113 Votes on 98 Posts
Is.this in a kitchen? If so the lights should not be sharing a circuit with the receptacles.
Old 02-04-19, 08:48 PM
C
yes, it is for the under cabinet lights....
Old 02-05-19, 04:54 AM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Hi, is that box located on the wall above a kitchen counter? if so as PC mentioned that receptacle needs to be on a 20 amp GFCI protected circuit and not connected to a lighting circuit.
Geo
Old 02-05-19, 05:39 AM
C
i see, what is the reason for that?
Old 02-05-19, 11:30 AM
Geochurchi's Avatar
Code requirements, receptacles for under cabinet lighting is OK, but receptacles on counter tops or elsewhere in the kitchen must be 20 Amp and GFCI.
Geo
Old 02-10-19, 05:38 PM
B
I can't exactly tell from the one picture but with 2 branches coming to the box, are both of their neutrals wire nutted together?
