Releasing locked in PushMatic breakers
Old 02-07-19, 11:10 AM
Q
Have changed some Pushmatics before. This box is different with a "locking" plate of formed sheet steel covering the center between the two rows which keeps the single pole breakers from coming out. It is about 3/4" deep. What is the method of removing that "lock"?
Old 02-07-19, 01:32 PM
A
Received 72 Votes on 65 Posts
Is the cover perhaps not aligned properly?
Old 02-07-19, 03:08 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Perhaps a picture would help us help you. https://www.doityourself.com/forum/e...-pictures.html
Old 02-07-19, 03:50 PM
Received 1,525 Votes on 1,408 Posts
Are you talking about a panel like this..............
Old 02-08-19, 07:15 AM
Q
Yes, that center bar looks like it. This is a branch box so no double breakers on it. Sorry I don't have any pics, camera quit and phone doesn't interface with my computer, yet.
Old 02-08-19, 04:26 PM
If you look at the top and bottom breakers...... I believe those brackets with the screws in them are removable. Try removing the bottom bracket first.
Old 02-08-19, 05:07 PM
L
Received 105 Votes on 91 Posts
Those are 2 pole breakers and screws on the handle tie are not removable.
That is part of breaker mounting. You cannot remove and don't need to remove.
You just unscrew breaker from the bus bar and pull the breaker. There are 2 clips that slides into the center bar.
Some times those clips are very tight and may have some rust hold it in the place. Put a flat had screw driver between the breaker and center bar and twist or ply slightly. That should release the breaker.
Old 02-09-19, 05:57 AM
Tolyn Ironhand's Avatar
Received 348 Votes on 301 Posts
Just email yourself the photos.
