Sub Panel to Cut off box
Old 02-16-19, 01:08 AM
Grimm_Book's Avatar
Hello,
i have Tuff shed barn and would like to run some power to it.
Its 15 ft from the meter which runs to a cut off box which runs to the main house.
Can I run from the cutoff box directly to a sub panel in the shed or does it have to run from the main house?
which is a least 75ft away.
Old 02-16-19, 01:59 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
By cut off box I assume you mean a disconnect. Does it have space for a breaker?
Old 02-16-19, 07:42 AM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
You will likely need to add an additional disconnect next to the existing disconnect unless it is a panel where you can add breakers. The feed to the shed could be fed off the existing disconnect, but the wires would need to be sized to the rating of the existing disconnect, which would be unnecessarily large.
Old 02-16-19, 12:12 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
I think I'd just replace that existing disconnect with a new main breaker loadcenter with feed-through lugs. The house can be fed from the lugs and a breaker can be installed in the panel under the meter to feed the shed.
Here is one:
https://www.homedepot.com/p/Eaton-BR...00RF/307646904
Old 02-17-19, 10:39 AM
Grimm_Book's Avatar
Yes the disconnect. It does have room for at least two more breakers.
Old 02-17-19, 10:44 AM
Grimm_Book's Avatar
Thanks for this. I thought it would need to be updated it is quite out as is, but I've had two electricians say it doesn't need to be which doesn't sound right.
Old 02-17-19, 11:31 AM
ray2047's Avatar
Then you can power the shed from it.
Old 02-17-19, 01:31 PM
Unless you are adding a very large load, or your service is undersized or in bad shape, upgrading the service is normally not necessary.
Old 02-17-19, 01:43 PM
Geochurchi's Avatar
Received 88 Votes on 83 Posts
Hi, if you have had 2 electricians look at it and they said it’s OK then what is the issue?
Geo
Old 02-21-19, 01:01 PM
Grimm_Book's Avatar
Geo
They came out to look at it, and both said they would get back to me with a part list, but both just ended up ghosting. So yeah I'm checking the checkers.
Old 02-21-19, 06:34 PM
CasualJoe's Avatar
A parts list?? If they are legitimate contractors they would get back to you with a price for the job and not a parts list.
