Kitchen outlet not working
Old 03-04-19, 10:31 AM
Hello. Our kitchen outlet is not working so we reset one of our GFCI outlets. The sevice panel (fuse box) controlling the outlet did not flip off. We then bought a brand new outlet, wired it up and it still didn't work. What should we try next?
Old 03-04-19, 11:15 AM
pugsl's Avatar
Received 19 Votes on 18 Posts
Problems like yours are at the last working outlet or the outlet that is bad. If any wires back stabbed move them to screws. Any wire nutted connection need to be taken apart and redone.
Old 03-04-19, 01:47 PM
Received 337 Votes on 315 Posts
You need to identify everything on the affected circuit. Then you need to determine what is and what is not working. That will usually help you to pinpoint a problem location.
Old 03-04-19, 06:09 PM
CasualJoe's Avatar
Received 21 Votes on 16 Posts
The service panel (fuse box) controlling the outlet did not flip off.
You also might try turning the proper breaker off and press the handle firmly into the "Off" position before turning it back on. You could have a tripped breaker and not know it. If it is tripped, you will feel and hear the breaker reset when you press it firmly to "Off".
