Outlet push-in release tabs
Old 03-04-19, 03:23 PM
I'm trying to replace some old outlets in my basement. I'm not seeing where to release these wires on this old outlet. There's no slack, so I"d rather not cut the wires if possible.
Am I overlooking a release mechanism somewhere ??
Old 03-04-19, 03:26 PM
pcboss's Avatar
Received 23 Votes on 19 Posts
Can't tell, but do you see a small.slot under the wire terminals?
Old 03-04-19, 03:29 PM
Received 21 Votes on 17 Posts
The little square holes right at the wire where pushed in. Use a very small flat head screw driver or piece of stiff wire such as a paper clip to push into the square hole.
Old 03-04-19, 03:33 PM
Received 55 Votes on 50 Posts
If that doesn't do it, try backing out the wire screws on the side and see if that helps. It's vague because I've only run into a few of them like that but looks remotely familiar.
Old 03-04-19, 03:49 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Maybe not the best but I have just used 18" water pump pliers to crush the receptacles then just picked out wires from the pieces.
Old 03-04-19, 04:02 PM
Geochurchi's Avatar
Received 15 Votes on 15 Posts
Hi, if you grab the conductors with pliers close to the receptacle and twist and pull they will usually pull out, do this if there are no release holes.
Geo
Old 03-04-19, 04:06 PM
Gee guys you can't see the release holes. I'm glad to see pjmax can see the release holes. See updated picture.
Old 03-04-19, 05:07 PM
Received 15 Votes on 14 Posts
That is what I usually do.
I usually don't carry screw driver small enough to fit release tab, that twisting and pull is often faster.
Old 03-04-19, 05:57 PM
pugsl's Avatar
Received 19 Votes on 18 Posts
Don't use the back stab connectors on replacement outlet use the screws on side.
Old 03-04-19, 06:08 PM
Tolyn Ironhand's Avatar
Received 52 Votes on 45 Posts
I also use the twist and pull method. If they don't come out doing that I just cut them off and restrip the wires.
Old 03-05-19, 05:28 AM
Holy crap............those are tiny. I totally missed those. Thanks for the help!!!
Old 03-05-19, 08:40 AM
In some cases the wire when extracted will be nicked and have to have the tip clipped off at the nick and then restripped.. More nicking if you twisted and pulled.
