2 of 4 Bathroom GFI not working
Old 03-04-19, 07:25 PM
Hey how’s it going ? Just bought a new house ( built 91) So I’m having an issue with some Gfi in my bathrooms. I have a total of 4 connected together. 1 in upstairs Hallway bath, 1 in master bath, lower bath and all connected to 1 GFI in the garage ( no clue why ). Al of a sudden the one in the upstairs hallway & master bath stopped working. ...
Hallway has power when checked by inserting plug checker & master does not.
Resets on outlets not working ( hard to press ). I killed all breakers and turned back on and nothing.... anyone have ideas on possible issue ? Can it just be 1 of 2 plugs went causeing the 2nd to not have power ?
Thanks a lot !
Old 03-04-19, 09:12 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Normally if only one circuit there would only be one GFCI. That GFCI would feed non GFCI receptacles from the load side. Sometimes if a GFCI feeds a second GFCI that can cause problems. If one GFCI feeds a second GFCI the second should be fed from the LINE not load side. How are yours wired.
