LED driver/transformer - inside or outside junction box?
Old 03-11-19, 10:42 AM
I've made a light fixture I'm selling online which includes a 6-light puck light system which includes the 120v->12V LED driver/transformer. Would there be issues if I left the driver outside the junction box and fed the 120V wires into a junction box where it would be connected to the AC power? Would the person buying this run into issues during installation with code?
Old 03-11-19, 01:10 PM
Received 77 Votes on 71 Posts
Unless you have your fixture UL certified the install will run into issues.
Old 03-11-19, 04:35 PM
Received 16 Votes on 15 Posts
It is fine to leave in the wall or ceiling if the driver you use is designed to be hardwired to NM cable as pictured.
Sheathing of NM cable should be under the strain relief (clamp).
However, I don't think your driver is designed for such installation. It looks like it was designed to have a lamp cord on AC input side.
Old 03-11-19, 05:09 PM
Tolyn Ironhand's Avatar
Received 55 Votes on 48 Posts
Even if it can be direct wires I would install it someplace that it can be accessed later. It may have to be serviced (replaced) at a later date.
Old 03-11-19, 05:12 PM
Yeah. It has to be accessible. I was referring to to ceiling or wall behind the light.
