No AC power to smoke detectors
Old 03-20-19, 12:08 PM
G
Similiar problem but i just added a gfi? to the upstairs bathroom, to make it work i had to wire all 4 wires to the top outlet? very inexperienced here. Should I just remove the gfi ? or is there a better way to wire it?
Separated from..... no-power-to-smoke-detectors.html
Old 03-20-19, 04:22 PM
A
Received 14 Votes on 14 Posts
You have replied to an old post. Not the biggest deal but, you are located in Canada. Canada has different code rules than the USA which is where this OP is from. Some of the answers in this post may differ from your location.
Old 03-20-19, 04:49 PM
CasualJoe's Avatar
Received 87 Votes on 77 Posts
Joed is from Canada too so I would think he will have an answer or at least a suggestion when he sees this thread.
Old 03-25-19, 06:18 PM
G
cool thanks for the reply
Old 03-25-19, 10:00 PM
Received 1,119 Votes on 1,039 Posts
Your thread didn't really belong with the one you posted in.
I'm a little lost. Your smoke detectors WERE fine until you added a GFI receptacle and what..... the GFI receptacle kept tripping so you wired everything to LINE side ?
That should be ok. I'd actually prefer the smoke detectors to not be protected by a GFI device.
