Split a circuit in sub panel
Old 03-28-19, 08:45 AM
A
Background - I have a dual pole 30 Amp circuit breaker in the main breaker box, located in the garage. It use to run an electric dryer down in the unfinished basement (previous owner). Iím now finishing the basement and would like to split the 10 awg (240 volt) line that was run to the basement into two 20 Amp circuits to feed the newly constructed areas (one for bathroom, one for office lights and outlets). The idea would be to install a sub panel, use the existing 10 awg line to feed the sub panel and use the two hot wires (red and black) to feed to two new separate circuits (20 Amp).
Question - is this acceptable to do? Any problems with this idea, and if so, what would be a better way?
Thank you for all your help!
Old 03-28-19, 09:00 AM
A
Received 50 Votes on 45 Posts
Assuming a 4 wire cable you should be fine.
If dryer is gone you could just replace the 30 amp DP breaker with a 20 amp (probably need AFCI) and simply splice the 10 gauge feed to the two 12 gauge circuits.
Old 03-28-19, 10:10 AM
Received 326 Votes on 281 Posts
It is acceptable if it is a four wire feeder. Some old dryer circuits only had three wire feed.
Old 03-28-19, 10:41 AM
A
Thanks
Thank you. Just to confirm it is a 4 wire line so Iíll proceed as planned. Appreciate the feedback!
Old 03-28-19, 11:41 AM
Be sure to not bond the neutral and ground. As a sub panel the neutral and ground must be kept separate.
Old 03-28-19, 11:44 AM
A
Ok thanks. I do that by removing the green ground screw, correct?
Old 03-28-19, 11:47 AM
A
Oh, also... I only need a small sub panel, so Iím planning on buying a small 100 Amp 6 spaces version. Iím a bit confused by the Amp rating on the panel itself. With what Iíve described, will 100 Amp be ok? Thanks again for everything!
Old 03-28-19, 12:55 PM
I
Received 44 Votes on 42 Posts
Correct the bonding screw is removed in the subpanel, and you usually will need to buy an add-on ground bar kit too. Yes a 100A panel is rated for use up to and including 100A, so it will be just fine at 30A.
Old 03-28-19, 01:59 PM
A
Thank you all for the help! Off to install!
