Running power to shed on existing circuit
Old 04-01-19, 10:20 AM
C
I am looking to run power to a small shed in my backyard that is about 25 feet from the house. I am only needing to power 2 small battery chargers, and 1 light. My panel is getting pretty full, so I would rather not install another breaker. There is 1 outlet in the garage that is on its own gfci breaker. Is it legal to run off of that outlet, to the shed? It is a 20a breaker, and it is wired with 12 gauge wiring. If it is ok to do this, would it be ok to just run 12/2 UF-B W/G wire from the outlet, down the outside wall in PVC, and directly bury it to the shed? Or how would you wire up this scenario?
Old 04-01-19, 10:29 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes. If it is GFCI protected you only need to bury one foot deep.
You will need a disconnect at the shed but a 20 amp toggle (light) switch is okay for that.
