Can one use NM into back of outdoor disconnect?
Old 04-03-19, 07:22 PM
D
Question Can one use NM into back of outdoor disconnect?
For a solar I need to put outdoor disconnect so Central Hudson utility company has easy access to the solar disconnect. Can I run NM through plywood sheating & siding into back of disconnect? I guess the same question can be asked if it was a disconnect switch for an a/c condenser. Does this meet NEC code?
Thanks, Dino
Old 04-03-19, 07:42 PM
Tolyn Ironhand's Avatar
Received 252 Votes on 220 Posts
Yes, that is fine.
