Cloth wiring, dead switch replacement.
Old 04-21-19, 03:31 PM
N
I would think this is fairly straight forward, I am living in an old house.
The wiring is cloth covered. (Owner knows, and is planing on getting the house re-wired for today's standards.)
A single pole switch connected to an outlet has gone bad and needs to be replaced. It doesn't look like it's daisy chained at that point, and the only things connected to the outlet is a lamp and alternating things. Those things include the following :
Chargers for cell phones, portable game systems, and holiday lights.
Do I need a specific type of switch for this, or can I get a cheap one?
Looking to buy one from Home Depot.
Thank you in advance.
Old 04-21-19, 04:41 PM
Z
Received 72 Votes on 68 Posts
If it really just needs a replacement switch, any standard switch will work. I wouldn't get the cheapest ($0.89) version... get something half decent for 2 dollars. All are rated for 15/20A so you should be fine.
Though switches typically don't go bad completely. They do get finikey when they get old, but if it's completely not working, you may need to troubleshoot some more.
Old 04-21-19, 06:34 PM
N
Ok, I was planning on spending between two and five dollars after tax.
The switch didn't completely die, what's happening is that the switch needs to be pressed in when flipping it. I took a quick look at it, and it uses the old connector with hot on one side and neutral on the other.
Old 04-21-19, 06:36 PM
Received 180 Votes on 161 Posts
It's not hot and neutral. It's black and white. Not all whites are neutrals.
You have a switch loop.
Old 04-22-19, 06:36 AM
N
Ok. Well I have a ticker, so I'm not worried about anything. I have replaced switches and outlets before.
