Wire too big?
Old 04-29-19, 08:40 AM
L
Wire too big?
I have a 30 Amp 220 circuit breaker with # 10 wire running about 34 ft. I want to put a 20 Amp receptacle on it but the wire looks too big for the receptacle. Would like to use the existing wire for that run.
Thanks, Charlie
Old 04-29-19, 10:05 AM
E
Received 17 Upvotes on 16 Posts
Receptacles have a spec on the wire gauges they accept, and it's usually shown on the back side.
The NEC table 210.21 (B)(3) requires that only receptacles with a 30A rating can be placed on branch circuits with a 30A rating. You could replace the 30A breaker with a 20A and install the 20A receptacle, leaving the 10 AWG run in place with a 12 AWG pigtail at the receptacle if necessary. That of course assumes there aren't other loads on the circuit requiring it to have a 30A breaker.
Old 04-29-19, 10:21 AM
I
Received 45 Upvotes on 43 Posts
Reduce the breaker to 20A. A 20A receptacle will take #10 wire either on the screw or the back wire plate.
