wire question: replace an old ceiling light
so I opened up an old ceiling light, and
There are 4 sets of wires in the wire box, three of them have 3 wires(white, black, ground), and one has 4(white, black, ground, and red)
*All 4 ground wires are capped together.
*All 4 black wires are capped together.
*All 4 white wires are capped together, with a new one coming out of the cap to the old light.
*The red wire goes to the old light.
So basically the old light has only a red and a white wire, no ground, it that right?
I am going to install a new light, should I still use the red, white, and connect the ground this time?
If the new light fixture comes with a ground wire (probably a green wire), that should be connected to the grounds.
Fixtures and appliances only have grounds if they are metal.
Your old light fixture probably did not have a ground. Was it a porcelain or plastic light bulb base?
