Odd electrical issue
Old 05-18-19, 10:49 AM
T
I have a breaker that keeps tripping, the breaker controls power to 2 bedrooms, no GFCI plugs involved. Unplugged everything, breaker still trips. Started trouble shooting electrical outlets, nothing burned or looks strange, removed one outlet and was able to get the breaker to stay on. This is providing power only to the fan/light in one room, no power to any of the outlets, with the one removed. Each outlet is daisy chained, has 2 neutral/white and 2 hot/black. What’s the next step you all would suggest? I have multi-meter, plug tester. Thanks
Old 05-18-19, 10:54 AM
Received 1,480 Votes on 1,368 Posts
Welcome to the forums.
Divide and conquer. Pick a point somewhat in the middle of the circuit and open it.
How old is the house....... what kind of wiring ?
If it's older wiring..... especially metal clad like BX..... the wiring can get shorted where it enters the box at the clamp. Insulation can break off. Sometimes the wiring is pushed to the back of the box when inserting the device and it hits the clamp and shorts.
Use a multimeter set to ohms to check from black to ground.
Old 05-18-19, 11:01 AM
pcboss's Avatar
Received 113 Votes on 98 Posts
Since you have already divided out part of the circuit and the breaker stays on it means the issue is downstream of the split. Everything upstream is good.
Old 05-18-19, 11:11 AM
T
House was built in 2012. When checking Ohms from black to ground, what am I looking for to know whether it’s good or not?
Old 05-18-19, 11:19 AM
There should be no resistance measure from black to ground.
Old 05-18-19, 11:33 AM
T
Not following what your saying Max, breaker stays on with one outlet disconnected and the fan/light will work. All other lights, outlets will not work. Are you saying the issue is in the fan/light?
Old 05-18-19, 11:54 AM
I had misread what you wrote. The problem is beyond what you have opened.
Old 05-19-19, 10:39 AM
T
Thanks for the help, found the short. It was the light in the closet, all good now.
