Ceiling Fan/Light with 3 way Switches for both Fan Light
Old 05-19-19, 05:43 PM
Exclamation Ceiling Fan/Light with 3 way Switches for both Fan Light
Hey ya'll, new here and could use some help. I want to have 4 switches total, 2 on each side of the room. One set for the light and the other for the fan.
I have the power (14/2) coming in at the middle, in the box for the ceiling fan. Then each switch box has 14/3 running to the box for the ceiling fan. At this point I realized I don't know exactly what I am doing for this since I have not found a diagram for this.
So, is this do-able? If so, how? Nothing is connected to anything yet, so it is not too late for me to change how anything is run. I would greatly appreciate a detailed explanation/diagram since this is outside my basic understanding.
Thank you!
Old 05-19-19, 06:54 PM
Received 15 Votes on 14 Posts
You will need one more 14/3 cable between junction box and switches.
One way you can accomplish this without pulling new cable is using a smart switch or some other type of remote switches.
You also could just get a ceiling fan remote controller with 2 remotes. (Get 2 sets or some how purchase an extra remote). If you set the code of both remote same, both will control same controller.
jakeneedshelp voted this post useful.
Old 05-20-19, 05:37 AM
Received 75 Votes on 69 Posts
You need to do this twice. Once for light and once for fan.
You need two 14/2 cables running to each switch box from the fixture.
Old 05-20-19, 06:20 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
But does not meet 2011 code requiring a neutral in the switch box even if not needed. (Except if easily added.) Easiest is to bring power to one switch box.
Power at the light/fan is more complicated. Note the need for 4-conductor cable (black, blue, red, white) which might be harder to find.
Old 05-20-19, 08:46 AM
Received 28 Votes on 24 Posts
Be aware that common in the above figures is referring to the switch terminal and not AC neutral which is sometimes referred to as common as a carryover from DC power. Switches are controlling the AC hot wire.
Old 05-20-19, 11:00 AM
ray2047's Avatar
Here is the actual switch wiring. At the fan black to black, red to blue (light), white to white.
I
How hard to move it? You may not be able to find a fan rated box that can hold the number of wires you will end up with. If I have time I'll try to draw it.
Old 05-20-19, 01:23 PM
I can move the power to the switch box fairly easily- since that seems like the best way to do it! Thank you so much, that illustration helps immensely! Much appreciated
