"load" side of gfci
Old 05-22-19, 09:27 AM
"load" side of gfci
Checking to see If I have this correct:
I want to add an outlet in a bathroom.
If I connect a "regular" outlet to the "load" side of an existing GFCI, I think that the new outlet will have the GF protection provided by the GFCI.
Is that correct, and is it better to do that than to add a second GFCI outlet instead of a "regular" one?
Thanks in advance.
Old 05-22-19, 09:57 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Connecting to the load side of the GFCI is correct. There is no need for the extra cost of a second GFCI. If you did use a second GFCI it would connect to the line side not the load side.
Old 05-23-19, 10:43 AM
Thanks Ray, I appreciate the options!
Old 05-24-19, 05:43 AM
Received 17 Votes on 17 Posts
If the second receptacle is near the first then you will probably prefer to run the cable from the load terminals of the first (, GFCI,) receptacle to an ordinary receptacle in the second location.
If the second receptacle is some distance away, such as in the next room, you may prefer to use a GFCI receptacle there and feed it with a cable tied in to the line side terminals of both receptacles.
