Half of the outlets in my office do not work
Old 05-28-19, 07:07 PM
L
This is becoming frustrating. There are four wall outlets in my home office. Two of the four went dead a few weeks ago. Also the light switch in the bathroom next to me and the light in the hall outside the office.
Here is what I have done:
Replaced the two wall outlets and light switches
Checked the GFI, it is in one of the bathrooms up stairs.
I bought a Tacklife to check the outlets. Big surprise the to non-working show dead and the outlet I thought might be feeding the rest of the circuit showed correct.
Any suggestions will be REALLY appreciated.
Thanks!
Brian
File Type: pdf
Old 05-28-19, 07:27 PM
pcboss's Avatar
Received 42 Votes on 37 Posts
Try these troubleshooting steps.
Do you have any test equipment?
Sticky
Troubleshooting a dead receptacle or light, Basic Terminology &...
Old 05-28-19, 08:02 PM
L
Yes, I replaced the good outlet and made sure the wires were screwed in. Did the same with the other outlets and wall switches I replaced. I also took off the wire nuts, unwound them and used new wire nuts.
Equipment:
Voltmeter
Tacklife outlet tester
Old 05-29-19, 06:13 AM
Geochurchi's Avatar
Received 26 Votes on 25 Posts
Hi, have you checked the fixture? Pull the fixture down and see how many cables are in the box, DO NOT BREAK ANY SPLICES , just note what is there, maybe a pic or two.
Could be a loose splice in there.
Geo
