In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Hair Dryer wonít work in bathroom plug
Old 05-29-19, 05:35 PM
B
Iím in need of some help, my wife was using her hair dryer in our bathroom when it tripped the breaker. I reset the breaker and told her she was good to go but when she plugged her dryer into that outlet it didn't work. I tried a night light and my electric razor, both worked. So I tried the hair dryer back in the outlet and it didnít work, I then tried other plugs and the hair dryer worked fine so I went back to the outlet that tripped and it wouldnít work. Does anyone know what the problem is?
Old 05-29-19, 05:41 PM
Received 295 Votes on 254 Posts
Plug in the night light and then try the hair dryer. Does the light go out?
YES. loose connection somewhere.
Old 05-30-19, 05:37 AM
B
Received 100 Votes on 87 Posts
If the outlet in the bathroom is GFCI protected, this would indicate the hair dryer wiring is defective and should be repaired/discarded.
Old 05-30-19, 10:32 AM
D
Received 9 Votes on 8 Posts
Does the hair dryer have a gfci on its cord? Mine does
Old 05-30-19, 11:53 AM
Received 1,322 Votes on 1,222 Posts
The blow dryer appears to be working in other locations.
Old 05-31-19, 06:01 AM
the_tow_guy's Avatar
Received 62 Votes on 51 Posts
Bad cord maybe? Try wiggling it around when it's working to see if it cuts out?
Old 05-31-19, 06:23 AM
Geochurchi's Avatar
Received 87 Votes on 82 Posts
Hi, blow dryer could work in other locations if the outlets arenít GFCI protected, is the circuit GFCI protected?
Geo
Old 05-31-19, 06:26 AM
XSleeper's Avatar
Received 779 Votes on 718 Posts
If you READ the original post you will find that the outlet in question still works and the hair dryer works in other outlets, but according to the op it does not work in the problem outlet... while other items do.
Old 05-31-19, 09:29 AM
E
Received 17 Votes on 16 Posts
What joed said in the first reply should be done. Assuming it's the usual duplex receptacle in the bathroom, plug the nightlight into one receptacle and then plug the blow dryer in the other. If turning the blow dryer on causes the night light to go off then there is a connection but it's a poor connection. The connection might be good enough for the nightlight or electric razor, both of which draw very little current, but not for the blow dryer which draws much more current.
Old 05-31-19, 11:20 AM
Still waiting for the results the test I requested. Night light are very low current draw. A bad connection may not manifest with low current.
Try the night light and the blow dryer together.
Old 06-04-19, 10:34 AM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
Appears the OP was just another "One Hit Wonder".
Old 06-10-19, 05:50 AM
B
Smile Hair Dryer defective
So i tried plugging multiple things into the socket over the weekend and all worked, eventually I even got the hair dryer to work. I opened the plug and all wire connections were OK.
As someone said when the breaker tripped day one it was because the dryer cord had gone bad. Eventually i noticed as I moved the retractable cord in and out some the dryer would kick on and off.
Thanks for all the suggestions and help
Old 02-16-20, 09:31 AM
A
Found the problem
I had the same issue. Dryer would work for a while in a different outlet then would stop. I was down to one outlet in the house that worked for everything but my blow dryer. I discovered the prongs that plug into the outlet stopped making connection. I bent them out a little and now my blow dryer works in all outlets again. Hope this is the fix you are looking for for.
