Do I need Arc Fault Breakers ?
Old 06-02-19, 05:04 AM
I have a new Square D main breaker panel in my new build, I went to buy breakers so I could finish wiring in my panel box and the guy said I can't use regular breakers anymore, I need to use ARC Fault Breakers which were about $43 apiece. Is this something the electrical code changed that you HAVE to use ARC fault breakers now?
Old 06-02-19, 05:07 AM
Most areas of the home require arc faults now.
What part of the home was the new circuit going to serve?
Old 06-02-19, 05:13 AM
Tolyn Ironhand's Avatar
Yes. The requirement of AFCI breakers has been slowly phasing in over the last 4 code cycles. Just about all living spaces in a dwelling are required to be AFCI protected including:
Bedrooms, kitchens, family rooms, living rooms, dens, libraries, parlors, sunrooms, rec rooms, closets, hallways, and laundry rooms.
AFAIK - spaces like garages, unfinished basements, and workshops should not require AFCI protection but local requirements may amend that.
Old 06-02-19, 05:55 AM
Not yet required for bathrooms even in latest NEC. Local codes might, though.
Old 06-04-19, 04:54 AM
Guess I'll just have to bite the bullet and buy the new style breakers..
