GFCI code kitchen counter?
Old 06-02-19, 01:11 PM
R
Question GFCI code kitchen counter?
What is the code for CFCI receptacles as far as how far they have to be away fro a water source? Do all kitchen counter receptacles have to be GFCI?
Old 06-02-19, 02:17 PM
Tolyn Ironhand's Avatar
Received 862 Upvotes on 725 Posts
All kitchen counter receptacles in a dwelling are required to be GFCI protected regardless of their distance from a sink.
In other locations, GFCI protection is required for any receptacle within 6' of a sink.
There is a lot more locations that require GFCI protection so if you need more info please ask.
rufunky voted this post useful.
Old 06-02-19, 02:19 PM
P
Received 2,108 Upvotes on 1,887 Posts
All outlets serving the kitchen counters must be GFCI protected. There is no specification as to distance from a sink or water.
Old 06-02-19, 02:22 PM
R
Ok, thank you, gentleman. Looks like I will have to go back and get the contractors pack.
Old 06-02-19, 02:27 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi, Contractor Pack? not every outlet has to be a GFCI, 1 GFCI receptacle can be used to protect several receptacles on the same circuit.
Geo
Old 06-02-19, 10:48 PM
Received 1,262 Upvotes on 1,203 Posts
Or the breaker could be GFCI as well.
It's actually not a good idea to have multiple GFCI protection on one circuit so if you do put in multiple GFCI receptacles, make sure each is being fed from the Line side of any previous one, not the Load side.
