Wiring help
Old 06-05-19, 03:12 PM
T
Wiring help
I removed 2 enclosed box light switches, mobile home, to install updated ones, The switches are for 2 seperate lights. I cannot figure out how to hook wires back up since it keeps flipping breaker. There are 2 separate wires coming from below, 2 separate wires going up, to lights I guess, and 1 wire going switch to switch. Not sure which is source from below or if both are source. They had both wires coming from below to first switch, 1 wire going switch to switch and 2 wires coming from second switch going up. Don't want to tear down sheetrock if I don't have to.
Old 06-05-19, 04:23 PM
ray2047's Avatar
You need to check each cable with a multimeter to find which is live.
Old 06-05-19, 05:48 PM
Received 3,485 Upvotes on 3,128 Posts
If it worked before there would be absolutely no need to "tear down sheetrock."
Old 06-06-19, 08:36 AM
d_s_k's Avatar
Received 19 Upvotes on 17 Posts
Maybe some pictures may help us understand this better?
