3 way switch
Old 06-13-19, 09:38 AM
A
3 way switch
I have 3 sets of wires coming in to My electrical Box. One is a outside power source 1 is the 3 way wires 1 goes to the lights I cannot figure out how to wire this properly does anybody have a diagram.
Old 06-13-19, 10:09 AM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
By electrical box are you referring to a switch box? post some pics of what you have there.
Geo
Old 06-13-19, 10:47 AM
Received 442 Votes on 367 Posts
Attachment 105981The wire colours between the switches might be different. You need to open the other switch and verify which wire on the common(black) screw. The other two don't matter. They are interchangeable.
Old 06-15-19, 08:03 AM
A
I have 3 black wires 1 from power source 1 from 3 way wire and one to my lights. Same with white wire and 1 red. I took it apart because I was going to make it a Sensor lite switch so I did not pay attention to how it was wired. Any help would be appreciated.
Old 06-15-19, 08:20 AM
Received 2,963 Votes on 2,674 Posts
You have three cables there. One is the supply and is hot. One is the light. The other is the three way switch. The wiring is very easy but you need to pull out the other three way switch and see what wire color is on the odd/dark/black screw. Don't disconnect that switch.
Joed's diagram is what you have but we need the common wire to finalize it.
Also make sure your sensor switch is three way compatible.
What model number sensor did you get ?
Old 06-15-19, 09:08 AM
A
I'm sorry that was what I was going to put in but now I'm back to a regular toggle switch which is a 3 way switch And I remember when I took it a part a black wire was wire nutted to a white wire
Old 06-15-19, 09:11 AM
We still need the wire color on the dark screw of the second switch.
Old 06-15-19, 09:18 AM
A
The one labeled common witch is the Bottom of the two screws is black going to the three way wire red is above that and white is by itself
Old 06-15-19, 02:02 PM
Ok.... I labeled the screw terminals in Joed's diagram but that is what you need to follow.
The location of the screws on the switch is unimportant as long as the black screw is observed.
Based on the switch you got..... there may need to be some slight rewiring.
If you post the model number I can give you exact directions.
Old 06-15-19, 04:13 PM
A
Tm873-WCC10 it is a legrand
Old 06-15-19, 04:54 PM
My apologies.... you're using a standard 3w switch. That will connect like switch 1 in the diagram.
Old 06-16-19, 07:46 AM
K
Hi guys
Thanks for the replies in this thread, last week I was trying to figure out how to wire a 3-way switch and ran across this complete easy tutorial https://besthomegear.com/how-to-wire...-light-switch/ that has illustrations and videos and made it very easy for me to understand, and complete the wiring myself. Maybe it will help some of you as well, Cheers
Old 06-16-19, 08:23 AM
That is one way to do it. If I was starting from scratch that is the way I would probably do it. However there 8 different ways to do it and that is not how the OP's is wired.
PJmax voted this post useful.
