Single pole thermostat L1 and T1 indentification
Old 06-13-19, 12:16 PM
L
Hey, I could use a little guidance. I am trying to change 3 thermostats in my home for my baseboard heaters. Nothing wrong with the old ones just out dated and yellow, they work fine.
I bought 3 new Honeywell CT410A's to replace the old Honeywell thermostats. The wires on the old thermostats are not labelled as L1 and T1. I used my voltage tester to check for the load line but I get a reading on both wires. Not sure how to proceed.
I have attached some pictures of my wiring.
Help appreciated. Thanks.
Old 06-13-19, 12:18 PM
I
Received 45 Votes on 43 Posts
On that type of thermostat, it doesn't matter which is which.
Old 06-13-19, 12:33 PM
L
So, I can connect either black comming out of my box to either of the blacks on this new thermostat, pictured below? Is this correct? They are interchangeable? No wrong way to connect them?
I just want be absolutely certain. Thanks
Old 06-13-19, 01:35 PM
L
Received 170 Votes on 146 Posts
Yes. it doesn't matter which wire goes to which.
It is basically just a switch.
