Need Wiring Help... Anyone Have a Diagram, Please?
Old 06-27-19, 05:14 PM
K
Running a new circuit in a gutted living room, so I can run wire pretty much anywhere, easily. Here is what I am trying to do...
-Two 3-way switches that provide power to 7 half-hot outlets.
(Am I right that the power would have to go to an outlet first in this set-up?)
-Would also like to power a ceiling fan on a Lutron speed-control switch off of this circuit... rather than putting the fan on it's own circuit.
I am very surprised that I haven't been able to find a wiring diagram of the switches / half-hot circuit, as this seems pretty common in many homes. Can anyone help please... and THANK YOU?!?
Old 06-27-19, 05:24 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
To wire split wired receptacles you just need xx-3 cable between the switches and the receptacles. Make the black the constant hot and the red the switched hot. You will need to break the tab on the brass side.
Old 06-27-19, 05:27 PM
K
Much appreciated! Do you happen to know where I could see a diagram of that? Just having trouble visualizing. Where would the power come in?
Thanks again!
Old 06-27-19, 06:00 PM
Received 249 Votes on 219 Posts
With the new code requiring neutrals at all switches this will require a 4 wire cable. between the switches.
Here is two receptacles. Just add as many as you want the same as the connection between one and two.
Name:  sw-sw-recpt recpt.jpg
Old 06-28-19, 05:26 AM
B
Received 88 Votes on 77 Posts
Just a clarification. The 4-wire cable should go between the 2 junction boxes containing the 3-way switches. The diagram in post 4 shows the 2 wires between the switches don't go through the junction boxes, therefore you wouldn't need a 4-wire cable between the 2 junction boxes containing the 3-way switches.
Old 06-28-19, 07:10 AM
Yes of course the all the wires go through the box. Here is a revised diagram.
Old 06-28-19, 12:43 PM
pcboss's Avatar
Some of the conductors are needed for functions outside of the switching. The black that continues as a blue is the constant hot. The white is the neutral carrying through.
