Need help with new dimmer switch
Old 07-01-19, 07:16 AM
D
Question Need help with new dimmer switch
Hello all,
I'm new here, hope this is the right place to ask a question. I'm swapping a standard 3-way switch out for a new Lutron dimmer (Lutron CTCL-153PDH), but the existing wiring doesn't seem standard, so I'm hoping for some help. I attached a picture of the current setup. I omitted the ground wires from the diagram for simplicity, but they are there. I also attached a pdf of the install guide Thanks in advance for any help!
Drumanji
File Type: pdf
Old 07-01-19, 07:30 AM
Received 237 Votes on 208 Posts
Looks very normal to me. What is your problem?
The black wire on SW1 top right is your common. It connects to the black common wire on the dimmer.
The red and whites connect to the red dimmer wires.
Old 07-01-19, 07:33 AM
D
Thanks Joed, I guess it doesn't look normal to me in comparison to the install guide provided with the switch. I'll give it a shot.
