WeMo 3 way switch installation - dumb Q I'm sure
Old 07-03-19, 01:45 PM
W
Received 1 Vote on 1 Post
Hi,
I've installed many many switches/outlets, including a WeMo single pole switch (years ago). I can copy the existing wiring essentially.
In this case the wire that is connected to the black screw of the existing 3 way switch is actually a continuous wire that is wrapped around the screw (LINE/LOAD).
The WeMo instructions indicate to remove this wire and connect it to the black wire on the WeMo switch.
Do I need to cut this wire and attach all 3 with a wire nut? Or???
Thank you!!
https://www.belkin.com/us/support-pr...4000004HVCEAA4
Old 07-03-19, 03:22 PM
Received 238 Votes on 209 Posts
Yes. cut the wire and connect all three with a wire nut.
Old 07-03-19, 03:26 PM
W
Well, thank you for the quick reply! So much appreciated!
