My Siemens load center door doesn't close
Old 07-06-19, 06:08 PM
D
I want to finally deal with with an issue that I have put aside for a while.
My Siemens G4040MB1200CU load center door does not close. Not sure if there was a manufacturing defect, missing part, or latch not installed correctly.
There is nothing for the "hook" to latch on.
Does anybody see what is wrong?
When doing a google I cam across this picture
https://www.ebay.com/itm/SIEMENS-PAN...ty!60067!US!-1
In this case there is a "lip" stamped out on the left.
Old 07-07-19, 08:18 AM
CasualJoe's Avatar
Looks like just a manufacturing defect to me. I would normally just take the cover/door back to where I bought the panel. The alternatives would be to buy a new cover/door or just live with it.
Old 07-07-19, 09:08 AM
D
The panel is about 20 years old, installed by the builder/contractor when new.
So, taking back wold not work.
Are doors generally compatible?
Old 07-07-19, 10:04 AM
CasualJoe's Avatar
You may find the catalog number of just the cover/door on the label inside the door. If not, you'll need the catalog number of the panel to order a new cover/door. Any Siemens distributor can order the cover/door. Lowes might also be able to order it for you if you speak directly to the electrical department manager.
Old 07-07-19, 04:47 PM
D
Thanks. I will need to find a pro.
After lots of google searches I came to the conclusion that the G4040MB1200CU got replaced by P4040B1200CU.
https://w3.usa.siemens.com/powerdist...01-ALL-web.pdf
Not sure if the panels are built the same. In any case I did not find door part for newer panel either.
Old 07-07-19, 05:11 PM
F
When you attempt to close the door do you just push on the door? With my Siemens panels I find I have to put my finger in the latch and move it when closing the door.
The following users liked this post:
Old 07-07-19, 05:21 PM
Tolyn Ironhand's Avatar
A small magnet would likely do the trick.
Old 07-07-19, 06:42 PM
D
@Furd: I tried everything. The latch simply has nothing to grab on to.
@Tolyn Ironhand: I am currently using some advertisement magnets. Hoping to please any future home inspector...
Old 07-07-19, 07:07 PM
L
Glue small neodymium magnet at top and bottom corner. Will be much stronger than advertisement magnets.
If you want replace the cover, try cutting a slot with dremel or grinder and bend the tab out.
There is nothing to loose if you plan on replacing the cover anyway.
Old 07-18-19, 06:27 PM
D
that was a great idea. I got very thin magnets:
https://supermagnetman.com/products/...nt=11410270723
