100AMP Breaker Panel - Wiring Advice
Old 07-07-19, 10:09 AM
D
Hello!
Photo of panel to be linked below as a reply.
I have taken on the task to wire a new 100AMP main electrical panel.
Have the permits from ESA. Want to make sure it's top shape.
Change out is from an old 100AMP Fuse box.
I have the two main legs feeding into the 100AMP breaker. The neutral is fed to the neutral bar. The GEC to the ground at the top.
I've used dielectric grease on connections thus far.
I would just like to confirm that this is a good setup before I start placing in the breakers.
Thanks folks!
Full size image: https://imgur.com/z0HLg9M
Old 07-07-19, 12:06 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
The GEC must terminate on the neutral bus.
Old 07-07-19, 12:10 PM
Received 237 Votes on 208 Posts
Where did you get that panel? It looks like one from USA. If it is from USA, I don't think it will pass ESA. In Canada the main breaker is in a separate compartment from the branch breakers.
Is the front panel in two pieces or one? If it is in two pieces you are probably fine.
Old 07-07-19, 12:19 PM
CasualJoe's Avatar
joed, the OP's profile says he is in the USA.
Old 07-07-19, 12:22 PM
ESA is the Electrical Safety Authourity in Ontario so I guess that needs to be cleared up.
Also
Why is the neutral all taped? Is that a bare wire? It will not pass as a neutral if it is.
Old 07-07-19, 03:51 PM
pcboss's Avatar
Received 84 Votes on 72 Posts
Bond.screw? Breaker.hold down? White.tape.on neutral?
Old 07-07-19, 03:57 PM
I could be wrong about the bare neutral. Ignore that comment. But white tape instead black should be used.
Old 07-07-19, 04:18 PM
Tolyn Ironhand's Avatar
Received 204 Votes on 181 Posts
Grounding bushing needs to be bonded to the neutral or ground bus.
Ground wire should be taped green.
Old 07-07-19, 04:21 PM
Received 1,043 Votes on 967 Posts
The member is in Canada and needs to change his bio location to reflect that.
Old 07-08-19, 04:45 AM
D
Hi everyone,
I am located in Ontario. I will change that in my profile.
The main breaker is in a separate 'top' compartment. Others are in the bottom. It is a Siemens 100AMP, 24 circuit main breaker from Rona. Folks their seemed confident it would pass ESA.
I have wrapped neutral in white tape. Also, I have bonded the GEC to the ground bus bar with a #3 bare copper wire. Adjoined to that is a grounding wire from a water main pipe. I've wrapped them in green tape.
I have been using this image as a guide:
https://images.app.goo.gl/gwPGdU8fzyUPXgaU6
Old 07-08-19, 08:13 AM
CasualJoe's Avatar
Regardless, the GEC still must be terminated ON the neutral bus and not on the ground bar or a lug bolted to the panel box. If this is your main panel the neutral bus then gets bonded to the panel box. I am assuming this is a common requirement between the NEC and Canadian codes, but since we now know this is in Ontario there might be some differences in codes, joed would know.
Old 07-08-19, 10:02 AM
D
Thanks for the advice!
I now have the GEC and the water main grounds terminating on the neutral bus (which is bonded to the panel).
wrapped the main neutral in white tape. All the grounds in green tape.
What is the lug used for (if anything) that I had the GEC terminating to originally?
Old 07-08-19, 10:31 AM
D
Here is a URL to the setup now:
https://imgur.com/a/HpjGHxi
GEC to Neutral Bus Bar (black but with green tape)
Water main ground to Neutral Bus Bar
Bolted lug (top of box) to Ground Bus Bar (as suggested by Tolyn Ironhand [if I understood correctly]).
I'm thinking to connect the ground bus bars together and using 3 gauge wire. Then connecting these with a 3 gauge wire to the neutral bus bar. While it's not needed (as I understand) this way I do not need the panel to conduct a surge from the ground bars to the GEC.
Thanks for the help again.
Old 07-08-19, 11:31 AM
I don't know why you have all those wires on the right. I would just put the ground into the lug and install the green screw to bond the neutral and ground.
Old 07-09-19, 09:29 AM
CasualJoe's Avatar
joed, like I said in post #11, there may be some differences between the NEC and Canadian codes. By the NEC the GEC must be terminated on the neutral bus and not on the ground bar or a lug bolted to the box and then the neutral bus is bonded to the box.
