Line and Load on a 208v switch
Old 07-07-19, 07:27 PM
crazysaguaro's Avatar
Question Line and Load on a 208v switch
Hello,
Which ones of these wires are the LINE and LOAD wires? There is a red wire at the top connected to a gold(ish) screw and a black wire at the bottom connected to a black screw (same on both sides).
Thank you,
Gina
Old 07-07-19, 07:32 PM
pcboss's Avatar
Received 85 Votes on 73 Posts
That is a double pole single.throw switch. There is no line or load.
The wire loops should be clockwise around the screws.
Old 07-07-19, 07:38 PM
It's for a pool pump - I'm removing it and replacing with a "smart" switch. An electrician actually put those wires on so he put them on in the wrong direction.
The smart switch is below. The wires are:
BLACK line 1
BROWN line 2
Red load
Yellow load
Blue common
I know the BLUE common wire goes to the big bundle of white wires, but need to know how to hook up the red and black wires on this existing switch to the BLACK/BROWN/RED/YELLOW wires on the new smart switch.
Thanks for any help,
Gina
Old 07-07-19, 07:51 PM
Received 1,049 Votes on 973 Posts
In that box I see two red wires and two black wires. One pair is LINE and one pair is LOAD. You will need a meter to determine which red/black pair is the LINE/live one.
However..... I don't see any bundle of white wires. You are switching a 240v pump which doesn't use a neutral.
Old 07-07-19, 07:58 PM
The white wires are up in a different part of the box just above this one - I can access them easily.
So one of the red/black pairs are the LINEs and the other pair are the LOADs? If I get a meter, how do I tell which is which?
I am a novice trying to decide if I want an electrician to do this or if I can do it myself. I have hooked up smart switches inside the house, installed ceiling fans, etc with no problems - but this is a bit different.
Thank you,
Gina
Old 07-07-19, 08:12 PM
Turn the switch off. Carefully check the wiring with a meter.
The red and black that are live with the switch off is the line/live pair. The other is the load.
crazysaguaro voted this post useful.
