Connecting sprinkler controller to electrical outlet
Old 07-27-19, 03:45 PM
P
I have an exterior electrical outlet that I want to connect my sprinkler controller to. The face plate is flush with the wall. I found a while-in-use type weather box cover like this:
https://www.lowes.com/pd/TayMac-1-Ga...Cover/50372928
Is this supposed to be a permanent setup? I wonder if there is a better way to connect to the outlet. Thank you.
Old 07-27-19, 06:35 PM
Received 1,118 Votes on 1,038 Posts
That is the correct cover and is the only way to do what you want.
It is considered a permanent option.
Old 07-27-19, 06:56 PM
P
Thank you, sir. Will buy one and do the installation this weekend.
EDIT: My outlet is horizontal whereas the linked photo is vertical. Does it matter?
Old 07-27-19, 10:01 PM
P
I cannot edit the previous post.
I found the answer. There are 2 removable tabs, one at the bottom and the other on the right. For vertical mounting, remove the bottom tab. For horizontal, remove the other. Neat.
Old 07-30-19, 06:11 AM
P
The project is complete now. Thank you for the advice.
